May 28, 2018, 08:49:31 am
Pages: 1 ... 3 4 [5]
Author Topic: ArcText plugin  (Read 43043 times)
sibianul
« Reply #60 on: September 10, 2016, 23:25:32 pm »
Awesome plugin, but is there a way to "invert the arc", in the attached picture you will understand what I mean if you look to the OFF text, it's upside down, it will be great if there could be an option to invert it and have my OFF text more readable, for now I will rotate each letter by hand.
Anyway, great plugin. Well done!
« Reply #61 on: September 10, 2016, 23:39:21 pm »
Yes, use a negative radius in the plugin.
Using a negative value for Height give also another possibility. (revert the text without changing is position)
« Last Edit: September 10, 2016, 23:48:34 pm by dh42 » Logged
« Reply #62 on: September 10, 2016, 23:59:55 pm »
... and I just remember that I do a doc for that
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/ArcTextDoc.html
sibianul
« Reply #63 on: September 11, 2016, 00:32:30 am »
Thank you !!! Incredible fast as always, the community (those few people who help everytime) around CamBam is the best support you could have for a software
« Reply #64 on: September 11, 2016, 06:47:02 am »
Maybe you will find this plugin more versatile  ?
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/TextOnPolyline.html
« Last Edit: September 11, 2016, 06:50:02 am by EddyCurrent » Logged
sibianul
« Reply #65 on: September 11, 2016, 12:22:37 pm »
Thank you Eddy, I downloaded that also now as I'm sure I'll use it in the feature, nice to have this too added to cambam (my last resort was cambam for text on curved surfaces, but having the option in cambam is perfect)
kiwibrick
« Reply #66 on: September 02, 2017, 00:01:00 am »
Just trying to use this plugin but I cannot get the text size to change at all, doesn't matter what I put in the size box it stays the same, can change all the other settings though.
« Reply #67 on: September 02, 2017, 02:01:58 am »
post the CB file you have problem with. Not long a go I used this plugin myslelf an it worked fine.file
« Reply #68 on: September 02, 2017, 02:39:32 am »
To change text size, you must change the value in the "Height" box, not in "size" Wink
Doug_S
« Reply #69 on: December 17, 2017, 20:11:16 pm »
Can anyone tell me if ArcText works on CamBam v1? If not, is there another solution?
Doug
« Reply #70 on: December 17, 2017, 20:38:45 pm »
Works perfectly with CB V1.0 R14
« Reply #71 on: December 17, 2017, 21:12:55 pm »
Doug
Try this one, http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/TextOnPolyline.html
Doug_S
« Reply #72 on: December 17, 2017, 23:30:53 pm »
Thanks for the help!
Page created in 0.234 seconds with 18 queries.
