May 28, 2018, 08:57:53 am
Pages: [1] 2 3 ... 5
Author Topic: ArcText plugin  (Read 43045 times)
Hans_G
« on: June 27, 2008, 19:59:53 pm »
I'm familiar with DeskEngrave.  I made a plugin so that I could get the same functionality right inside of CamBam.  While not a big deal, I also like that it doesn't break the text into lots of small lines.  This one is built w/ the free version (remove the .txt extension), but source is attached if someone wants to build a Plus version.
* ArcText.zip (8.93 KB - downloaded 1072 times.)
* ArcText.dll.txt (24 KB - downloaded 916 times.)
« Last Edit: June 27, 2008, 20:05:12 pm by Hans_G » Logged
« Reply #1 on: June 28, 2008, 00:12:09 am »
Another fantastic plugin!  Thanks Hans!
I have recompiled your source for CamBam plus if anyone would like to use it.
* ArcText.dll.txt (24 KB - downloaded 748 times.)
davek
« Reply #2 on: June 29, 2008, 21:11:28 pm »
What have I done wrong?
lazer
« Reply #3 on: June 30, 2008, 02:18:16 am »
here this the right  Grin
in the Cambam+ it lacks CADFileView  Cry
* Arc_Text.zip (5.43 KB - downloaded 590 times.)
* Arc_Text-Src.zip (172.33 KB - downloaded 664 times.)
« Last Edit: June 30, 2008, 02:40:28 am by lazer » Logged
lazer = leisure -- Sorry my English
Miguel-
« Reply #4 on: June 30, 2008, 08:45:23 am »
Hi.
Im having troubles with this plugin.. Cambam(free and plus) informs that the .dll is expected to include ?assembly catalog? (or something like that -my computer speaks that in finnish and Im not quite sure that what it is in english) -the description is: HRESULT-exception 0x80131018
Im running on Vista with latest .net...
Sign here ________________
« Reply #5 on: July 02, 2008, 10:29:05 am »
I have done a bit of investigation into this...
In the ArcText project, under the project properties, Build tab, then the advanced button,
there is an option that says 'Debug Info'.  In the release build, this was set to pdb-only which I gather was confusing things.  I set this to 'none' and recompiled for both plus and free versions and seems to work OK for me now.  The plugin was working OK on the machine that it was compiled on, but not on other machines.
Fingers crossed, these builds should work.  Thanks again Hans!
* ArcText_plus.dll.txt (24 KB - downloaded 672 times.)
* ArcText_free.dll.txt (24 KB - downloaded 507 times.)
EAC
« Reply #6 on: July 05, 2008, 17:10:58 pm »
Still getting the 'expected to contain assemby' error with the new version on plus...  Downloaded a couple of times to be sure.
Miguel-
« Reply #7 on: July 05, 2008, 22:15:55 pm »
Same error also on free version Shocked
lazer
« Reply #8 on: July 06, 2008, 04:16:14 am »
* Arc_Text_Plus-src.zip (243.8 KB - downloaded 693 times.)
* Arc_Text_plus.zip (5.43 KB - downloaded 686 times.)
Hans_G
« Reply #9 on: July 06, 2008, 05:19:56 am »
Well darn, I was hoping there wouldn't be any problems.  Only a narcissist uses "hope" and "software" in the same sentence.
Folks that have had problems... is your CamBam installed at C:\Program Files\CamBam\  or somewhere else (i.e. D:\Program Files\CamBam, or C:\Best Program Files Ever\CamBam)?
« Reply #10 on: July 06, 2008, 23:12:11 pm »
Ah Ha!
I think I see the problem!!!
I think the DLLs were OK, but when you rename them as .txt and upload them, I gather the linux web server does some carriage return conversions which corrupts the .DLL
Thanks to lazer as he was the only one to sensibly zip up his dlls which worked OK.
RTChoke
« Reply #11 on: September 09, 2008, 22:14:23 pm »
OK I am either dense or forgetful, but tell me how to put this thing into CamBam (free version)?  I download the .zip, then what?  I unpacked it and did not see any sort of .dll in any of the subdirectories, except for cambamsomething.dll
I think we're all Bozos on this bus
« Reply #12 on: September 10, 2008, 09:12:43 am »
I'm getting a bit confused with this thread myself!  Shocked
To help reduce the confusion of which version is which (or possibly add to it depending on your point of view),
I have attached a zipped copy of the ArcText plugin for the CamBam free version.
Unzip the ArcText_free.dll in this zip file to the "...\Program File\CamBam\plugins\" folder.
When you restart CamBam, you should see "Arc Text Plugin" menu appear under the Plugins top menu.
* ArcText_free.zip (5.15 KB - downloaded 805 times.)
RTChoke
« Reply #13 on: September 10, 2008, 15:46:51 pm »
OK that worked.  Those other zipped files did not generate the .dll when I downloaded them.  There was a bunch of other stuff in there, but no arctext.dll (or whatever).
Thanks for doing that!  I'll give it a try.
RTChoke
« Reply #14 on: September 10, 2008, 19:38:44 pm »
Great plug-in -- I am doing a design at this moment.  It is much easier to do it right in CamBam than to have to paste it in.
One little hint -- if you select a negative radius, it puts the text underneath, right side up.  Y'all probably know that already, but I discovered that trick in DeskEngrave when I kept trying stuff trying to figure out how to do that.
Thanks again!
--R
Page created in 0.183 seconds with 18 queries.
