December 14, 2019, 21:44:46 pm
Author Topic: Custom View Toolbar buttons (Isometric view etc)  (Read 5967 times)
« on: November 26, 2012, 10:13:01 am »
I have just uploaded a new plugin which adds some extra 'View' toolbar buttons, including ISO...
http://www.cambam.info/ref/plugin.viewtoolbaraddins
The source code is also available, which demonstrates adding custom tool bar buttons.
The plugin just uses quick and dirty text labels at the moment, but if anyone wants to add their own fancy bitmap buttons they are more than welcome.  Smiley
Jeff_Birt
« Reply #1 on: November 26, 2012, 16:46:38 pm »
I added a 'Reset' button as well. It basically does the same thing as 'XY' but also does zoom to fit so the drawing is centered in the view. In other words it works just like the 'Reset' does in the context menu.
* ViewToolbarAddins.zip (2.77 KB - downloaded 237 times.)
« Reply #2 on: November 26, 2012, 18:57:40 pm »
Thanks Andy for his initiative.
I added the view orthogonal to your plugin.
I created a resource icon.
The file is complete, all users can replace this.
Andy you can use in future version of cambam.
The source code is attached with resource.
Thank you again.
* ViewToolbarAddins_Orth.zip (3.88 KB - downloaded 275 times.)
* ViewToolbarAddins_Orth-Source.zip (8.39 KB - downloaded 221 times.)
« Reply #3 on: November 26, 2012, 19:52:40 pm »
Nice  Grin
Thanks all  Wink
Just for info, that works also on L or only on N rev ?
« Last Edit: November 26, 2012, 19:55:08 pm by dh42 » Logged
alexr
« Reply #4 on: December 02, 2012, 06:43:21 am »
All I get is this.
As you can see I used latest software version (registered) and I followed the instructions to the letter.
using Windows 7, freshly installed, fully updated.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.MissingMethodException: Method not found: 'CamBam.UI.ViewProjection CamBam.UI.ICADView.get_ViewProjection()'.
   at ViewToolbarAddins.ViewToolbarPlugin.ViewISO_Click(Object sender, EventArgs e)
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripButton.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    Assembly Version: 0.9.4339.27541
    Win32 Version: 0.9.4339.27541
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%200.9.8/CamBam.exe
    Win32 Version: 2.0.50727.5460 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 2.0.50727.5462 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CamBam.CAD
    Assembly Version: 0.9.4339.27540
    Win32 Version: 0.9.4339.27540
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%200.9.8/CamBam.CAD.DLL
CamBam.Geom
    Assembly Version: 0.9.4339.27539
    Win32 Version: 0.9.4339.27539
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%200.9.8/CamBam.Geom.DLL
System.Xml
    Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Design
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
9nbngfo7
CamBam.OpenGL
    Win32 Version: 0.9.*
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%200.9.8/CamBam.OpenGL.DLL
CamBamLathe
    Assembly Version: 1.1.4338.23085
    Win32 Version: 1.1.4338.23085
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%200.9.8/plugins/CamBamLathe.dll
hqv4nxy5
CamBamPlus_Toolkit
    Assembly Version: 1.1.4338.23086
    Win32 Version: 1.1.4338.23086
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%200.9.8/plugins/CamBamPlus_Toolkit.dll
CutViewer
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%200.9.8/plugins/CutViewer.dll
HeightMapPlugin
    Assembly Version: 1.3.4338.23086
    Win32 Version: 1.3.4338.23086
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%200.9.8/plugins/HeightMapPlugin.dll
ViewToolbarAddins
    Assembly Version: 1.0.4713.18503
    Win32 Version: 1.0.4713.18503
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%200.9.8/plugins/ViewToolbarAddins.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
alexr
« Reply #5 on: December 02, 2012, 06:49:31 am »
Oh that error goes for all additional buttons on the tool bar via the new plugin
if you know how to fix this or need any further information please reply or PM me.
thanks
AlexR
alexr
« Reply #6 on: December 02, 2012, 10:14:15 am »
plugin doesnt work on 0.9.8 L which was the version i did the error report for but version N with the new views works fine.....
« Reply #7 on: December 02, 2012, 12:55:47 pm »
Hello AlexR
Does not work in version 98L, seed in version 0.9.8N (rc-4).
See image below.
Attention make a copy of file "CamBamPro.lic" and stores this copies.
Uninstall the old version completely.
And install the new version 0.9.8N (rc-4).
« Last Edit: December 02, 2012, 12:58:31 pm by BR52 » Logged
Page created in 0.121 seconds with 19 queries.
