December 14, 2019, 22:13:42 pm
Pages: 1 [2] 3 4 5
Author Topic: CamBam plus 0.9.8N (development release)  (Read 40986 times)
shovelhd
« Reply #15 on: November 18, 2012, 18:00:05 pm »
Thanks 10Bulls Just what I needed
« Reply #16 on: November 19, 2012, 10:10:12 am »
Andy, I can't obtain any toolpath with the thread milling plugin with this version Wink
Sorry, the thread milling plugin needed to be modified to work with 0.9.8N.
I have uploaded a new version (1.4) here...
http://www.cambam.info/ref/plugin.threadingmop
EDIT: oops!
« Last Edit: November 19, 2012, 11:15:40 am by 10bulls » Logged
« Reply #17 on: November 19, 2012, 11:14:11 am »
http://localhost:2300/ref/plugin.threadingmop
REALLY?  Cheesy
« Reply #18 on: November 19, 2012, 11:16:07 am »
REALLY?  Cheesy
Worked OK on my PC!  Tongue
« Reply #19 on: November 19, 2012, 11:20:37 am »
I'll bet it was FAST, too!  Cheesy
« Reply #20 on: November 19, 2012, 18:45:40 pm »
It work for me  Wink
GeorgeRace
Wobbler Engine
« Reply #21 on: November 20, 2012, 02:22:58 am »
Hi Andy and thanks for all the new functions and update.
when I start the program, if I don't hit the shift key to start in GDI, I get a pair of error messages at the bottom of the screen and it says it is using the default mode.
In that start up mode I do not get either the X or Y axis lines on the screen.  Turning them on and off from the View Menu does nothing either.
Am I missing something here?
George
Please check out my web site.
http://www.mykitairplane.com
Builder & Test Pilot of N73EX
« Reply #22 on: November 20, 2012, 09:15:17 am »
In the options menu select "OpenGL_Legacy" for the display mode and see if there's a change.  Or select "GDI" to not get error messages. I have an old nVidia card and also get these messages.
« Reply #23 on: November 20, 2012, 09:56:27 am »
Hello George,
Were you able to use OpenGL mode in the previous version?
The default behaviour is to try and start using the new 'shader' based OpenGL mode.
If this is not supported or errors are detected then it should resort to the legacy OpenGL mode and then GDI mode.
The aim is to make this selection as reliable as possible for all the varieties of video drivers out there, so it sounds like this still needs some work.
If you can send any information on the error messages that would be a big help.
As well as the error messages reported at the bottom of the CamBam window, there may be a file 'cbdebug.log' in the CamBam system folder which can be informative.
Another diagnostic that is helpful.
If you select 'Script - New - Python Script' from the top menu, then paste the following...
from CamBam.UI import OpenTkDiagnostics
OpenTkDiagnostics.OpenGLReportCaps()
Thank you very much for your help with this.
jmccracken
« Reply #24 on: November 20, 2012, 21:02:07 pm »
Thank you for adding ball-nose compensation in the 3D Waterline Finish!
« Reply #25 on: November 20, 2012, 21:46:45 pm »
From me to! Grin
Was much needed.. Wink
« Reply #26 on: November 21, 2012, 13:07:23 pm »
It wasn't in the new feature list, but the measure tool is vastly improved, as it shows the measurement directly as the mouse moves.  Props!
atwooddon
« Reply #27 on: November 21, 2012, 15:03:45 pm »
Just wanted to say I am impressed with the new features in 9.8N.  Have been using it since it was released and haven't had any issues.  The additional functionality all address areas I need to use and wanted.  Thanks a lot!!
« Reply #28 on: November 21, 2012, 16:54:13 pm »
Hello Andy,
my last language file for updating the language download table.
* translate_de.zip (44.2 KB - downloaded 225 times.)
GeorgeRace
Wobbler Engine
« Reply #29 on: November 22, 2012, 15:04:33 pm »
Andy, when i selected OpenGL_Legacy in the setup menu all the problems went away.
Thanks again for the work and the new version.  Will let you know if I see anything else that does not work here.
George
Pages: 1 [2] 3 4 5
Page created in 0.155 seconds with 19 queries.
