February 21, 2018, 10:30:18 am
Author Topic: Arc text script and engraving fonts  (Read 2001 times)
skray775
« on: May 23, 2012, 03:42:27 am »
I downloaded the Arc text plug-in and it works great!  Thank you!!!
Tonight I tried to use the single line engraving fonts found here:
http://www.mrrace.com/CamBam_Fonts/
and was presented with an error in saying that they are not true type fonts?
Any ideas on how to make that work?
GeorgeRace
Wobbler Engine
« Reply #1 on: May 23, 2012, 17:52:55 pm »
Interesting, they are indeed true type fonts that are written over themselves, making a single line when used with the engraving MOP.  If you do get an error when you compile the GCode, ignore it and go on.
George
Please check out my web site.
http://www.mykitairplane.com
Builder & Test Pilot of N73EX
skray775
« Reply #2 on: May 24, 2012, 00:49:52 am »
Restarted the computer and they were indeed recognized and would display but...
The double lines on some letters do not line up when curved. Take a capital K and
try it.  The K turns into 2 K's on top of each other. The O seemed to work fine?
I know nothing of fonts but maybe the starting line locations are a bit different
or something?
« Reply #3 on: May 27, 2012, 16:57:49 pm »
There is a tiny (can't remember how much at this moment) distance between the contours of the letters which are almost overlapping. TT fonts need to be closed contours to form a region which is filled with colour. On screen they are barely visible because of this.
I am using CorelDraw to make texts for engraving and there I set no fill but set the outline the width of the tool so I get a visual representation of the actual text when engraved.
One thing I've noticed is that if you use both fill and outline in CorelDraw, the exported DXF contains a double set of the text imposed over one another - something to do with the export filter.
Also better convert everything exported to curves before exporting.
Page created in 0.126 seconds with 18 queries.
