mofosheee
« on: February 28, 2012, 23:13:49 pm » |
Dear Cambamers
Suppose that I draw an image an save it as in a jpg format., what program is best for converting the image to dxf. Thank you
Orifice62
Offline
« Reply #1 on: February 28, 2012, 23:45:30 pm » |
Hi Mofosheee, Inkscape: http://inkscape.org/Heres your Turbo Flange.dxf I hope this works  Bret
« Reply #3 on: February 29, 2012, 12:57:45 pm » |
mofosheee.
Why not just draw it in a CAD program and save it as a DXF, as it's a much more predictable way of getting what you want?
mofosheee
« Reply #4 on: February 29, 2012, 15:15:49 pm » |
Martin
I am at the learining stage and don't even know the right questions to ask at this time. For tutorial purposes and if it makers sense to others, I was intending to download an image, load it to CamBam and produce tool paths and gcode.
mofosheee
« Reply #5 on: February 29, 2012, 15:50:13 pm » |
For instance, I convert and save the attached .jpg file to dxf. I open CamBam and and attempt to load the selected "dxf" file.
A window pops up informing me that the original was in inches and I am attempting to change units of measure to millimeters. I then select "no" to maintain the same units of measure (inches) then attempt to open the file.
Results are that:
1) mm's are again displayed in the units of measure window. 2) No image is displayed.
What am I doing wrong please?
Thank you in advance.
« Reply #6 on: February 29, 2012, 15:55:30 pm » |
mofoshee.
It's certainly a valid approach for some things, but I wouldn't recommend it for parts that have to be made to an exact size, although it's a useful tool for bringing in artwork.
You'll almost always have to mess around with areas of a drawing when brought in this way and the part you've given as an example (gasket/flange?), would be better made to some known dimensions, which is much easier to do in a proper CAD program - and some good free one are available, if that's what you want.
« Reply #7 on: February 29, 2012, 16:22:10 pm » |
Results are that:
1/ The pop-up window is telling you that the file is in mm's and is asking if you would like to make mm's your default unit setting for CamBam. However, because the file is in mm's, that is why it is displayed as such. 2/ There don't appear to be any objects in your file for CamBam to display. You aren't doing anything wrong, but problems like No2 are more common using the scan to cad technique. Martin.
mofosheee
« Reply #8 on: February 29, 2012, 17:01:29 pm » |
Thank you again. Hum, much much more to learn. Attached is a typical for instance dilemma for a part that I am trying to replicate for my rc airplane:
Jerry
« Reply #9 on: February 29, 2012, 18:38:33 pm » |
Jerry.
To get you going, here is the part drawn up in a CAD program from the dimensions shown in your picture.
« Reply #10 on: February 29, 2012, 19:49:49 pm » |
All programs with bitmap tracing capabilities produce inaccurate results. Depending on image resolution, contrast, and used method for finding and tracing the edges. I have a lot of experience in the field. Where there's no other way I prefer to trace manually and then edit the paths in a vector editor program. For example I have made a motor head gasket drawing to be laser cut from a scanned image, but it's a pain.
mofosheee
« Reply #11 on: February 29, 2012, 19:56:36 pm » |
Thank you Martin for that and all others for their valued input. Would somebody please suggest a CAD program that would compliment CamBam?
So much to learn
Jerry
Imagining
« Reply #13 on: March 01, 2012, 00:50:04 am » |
So much to learn
Jerry
It isn't so much the CAD program being compliant with Cam Bam, it is the file type. For 2D objects it is DXF files, for 3D there are other file types. For a easy and free start you should look at Google SketchUp. And yes, so much to learn, but we are all happy to help as others have helped us.
« Reply #14 on: March 01, 2012, 01:01:26 am » |
------------- Having developed several large 3D landscape models in Sketchup of real-world venues (theme parks, for setting up fireworks displays), I can say that I'd rather pay double for some unknown commercial CAD program that might not even work, than to get Sketchup for free.
