Home
Downloads
Forum
Shop
News
Home
Help
Search
Login
Register
Welcome,
Guest
. Please
login
or
register
June 19, 2013, 02:55:25 am
1 Hour
1 Day
1 Week
1 Month
Forever
Made by CamBam
Members Machines
CNC BZT PF 750P
Pages:
1
2
3
4
7
« previous
next »
Author
Topic: CNC BZT PF 750P (Read 10782 times)
Offline
Re: CNC BZT PF 750P
Reply #15 on:
May 07, 2011, 00:13:33 am »
Out of curiosity I looked up your machine. Its not exactly a cheapie is it.
Offline
Re: CNC BZT PF 750P
Reply #16 on:
May 07, 2011, 01:04:47 am »
Quote from: Bob La Londe on May 07, 2011, 00:13:33 am
Yes, the CNC + controller + 4th axis + alu table (option) + microlub + port from Germany to France ~6000€ with tax (8700$ US)
It's one of the least expensive of the "non-Chinese" machine sold in Europe with this work size ....
it's good material, but maybe too expensive ...
I first watched a Chinese machine
Like this
, but there appears to have many problems in all kinds especially with electronics and geometry.
Other problem with this Chinese CNC is that they are too slow (feedrate) for wood machining (~ 1000 mm/min max when machining, 1500 with rapid ... announced, 60% in real without lost step for guys on forums
A friend that have a 6040 say me that in alu, the precision of the final part is ~0.1mm
.. on the BZT, on my alu part I get 0.02/0.03 mm max of error on all dimensions.
I hope I've not made a mistake buying this machine, 4th axis problem worries me ... I don't understand what appends ..
Offline
Re: CNC BZT PF 750P
Reply #17 on:
May 10, 2011, 22:43:18 pm »
some job on the vice.
I must redo the jaws, I use 25CD4 (4130) to do this
On the free jaw, I must use a sheet of metal (0.05mm) to correct the perpendicularity.
Offline
Re: CNC BZT PF 750P
Reply #18 on:
July 12, 2011, 01:13:51 am »
Some news about machine and accessories.
The strange problem on my 4th axis is solved ... that comes from Mach3, settings problem. I've an output signal (unused) that is set on the same pin number that the "Dir pin" of the A axis, I just uncheck the unused signal all that run well .... one month to find that
I continue the job on the vise.
Exceptionally I made the effort to paint it
there is no crank, I must do it.
Finished
And with is little family
After the alignment problems that I have with the 4th axis when cutting "venus" I decide to add a "lardon" (don't know English name) to help the positioning of the A-axis and is tail stock. In addition the plate of the axis is not in the right direction, the holes are not in front of the slot of the table. I must rotate the plate of 90° to solve the problem.
Origin
Rotated and add a "lardon"
I create two "lardon" for the tail stock too, and at the same times suitable screw and T
Then I use Cambam to cut a box to store all this accessories.
Not hight quality plywood
Now I'll work on a lathe project to add on the CNc
There is still work to do on the drawing, but I hope I can start the project in august .... maybe
good night
Offline
Re: CNC BZT PF 750P
Reply #19 on:
July 12, 2011, 12:30:14 pm »
In English that "lardon" is a "key". Given that another translation for lardon is "bacon bit", it's an interesting choice.
Offline
Re: CNC BZT PF 750P
Reply #20 on:
July 12, 2011, 16:33:18 pm »
Hello Kvom,
Yes in French a "lardon" IS something like the bacon too
And a mill is called "fraise" (= strawberry)
And for a French, a "Bit(e)", it's not exactly the same things
It's a organic tool with variable size that is used for polishing "holes" ... and that is also the second brain of a man (and frequently the first )
Last Edit: July 12, 2011, 16:39:34 pm by dh42
Offline
Re: CNC BZT PF 750P
Reply #21 on:
July 12, 2011, 22:52:10 pm »
Quote from: dh42 on July 12, 2011, 16:33:18 pm
Ah, now I see where it came from into Bulgarian. The word we have is <freza> if you read it phonetically.
Bench_Top_Precision
Offline
Re: CNC BZT PF 750P
Reply #22 on:
July 22, 2011, 11:03:51 am »
I'm a sucker for detailed solid modeling. What software are you using?
www.benchtopprecision.com
Offline
Re: CNC BZT PF 750P
Reply #23 on:
July 22, 2011, 14:27:08 pm »
I use SolidWorks 2008
Bench_Top_Precision
Offline
Re: CNC BZT PF 750P
Reply #24 on:
July 22, 2011, 20:07:37 pm »
That would have been my guess. I've been solid modeling with Solidworks for about 8 years and I'm still learning new things the software can do. Nice work.
Offline
Re: CNC BZT PF 750P
Reply #25 on:
July 22, 2011, 20:17:59 pm »
Learning 3D softs as no end
and SW is not an exception ...
I use also 3D Studio Max from more than 15 years and I always discover new possibility ...
some drawings with 3DSMax
Bench_Top_Precision
Offline
Re: CNC BZT PF 750P
Reply #26 on:
July 23, 2011, 10:02:48 am »
Very nice work, especially the lathe.
Offline
Re: CNC BZT PF 750P
Reply #27 on:
July 23, 2011, 14:00:54 pm »
thank you
For the lathe, the job is in stand-by from a long time
.. I have "3dmax" period and "SW" period
It is on the "Audi S2" and "Pacific 231" that I have the biggest job.
Offline
Re: CNC BZT PF 750P
Reply #28 on:
February 15, 2012, 15:26:35 pm »
For Ruben ; I attach the config file for BZT PF750P (ball screw)
(can't find how to attach a file in PM)
If PF750C (trapez screw) change the max speed in motor tuning to 4000 for X and Y axis.
the file is set to handle 4th axis if needed.
I have slowed the max speed and acceleration for my use. (motor tuning ; config in mm)
X and Y = 6000 mm/min acc = 400
Z = 2000 mm/min acc = 400
original value are 7500 for X and Y in place of 6000 and 500 for acc ; and 2500 for Z
It's to height for my machine when T° is low in workshop !
PF-750P.zip
(21.8 KB - downloaded 27 times.)
serpvect
Offline
Re: CNC BZT PF 750P
Reply #29 on:
February 16, 2012, 17:04:00 pm »
David, thanks a lot for your reply!
Unfortunately I'm still experiencing some problems. I've also got a profile from the manufacturer directly, but both yours and their profile seem to be wrong for my driver.
Motor Output Step and Pin seem to be interchanged!
For example in your profile X Step pin #3, X Dir pin #2.
I've managed to get axis movement only with X Step pin #2 and X Dir pin #3. The same thing with all 3 axes. Besides I had to set Step Low Active for XYZ.
But still the movement is not stable, motors sometimes stall unexpectedly and immideately continues its movement.
I've switched to 25000Hz and set XY motor tuning to 160/4000/400 and step/dir pulse to 5/15. It became more stable now, but still not that good.
Btw mine is PF750P version too (ball srew), config in mm.
I'm now in doubt about my Mach3 station which is actually a Dell D610 notebook. As far as I know notebooks are not recommended for use. But it's specially prepared for Mach3 according to all the recommendations and Driver Test indicates "System Excellent" and the graph is quite a straight line. And yes, Mach3 is a licenced copy.
First of all I'm going to try a desktop PC and maybe an Ethernet-LPT interface (specially developed for CNC by local company). I haven't got other ideas at this time.
Sorry for being a nub, I'm just starting with CNC.))
Pages:
1
2
3
4
7
« previous
next »
Please select a destination:
Announcements
=> Latest News
Support
=> Installation Help
=> CamBam help (General usage)
=> Problem dxf files etc...
=> Scripts and Plugin Help
=> How to's and tutorials
=> Lathes and Turning
Resources
=> CamBam files (*.cb)
=> Scripts and Plugins
=> Post Processors (*.cbpp)
Made by CamBam
=> Members Projects
=> Members Machines
FeedBack
=> Bug Reports
=> Feature Requests
=> CamBam plus feedback
=> CamBam Shop Feedback
Loading...
