April 26, 2019, 05:35:15 am
Author Topic: Preparation of imported drawings  (Read 18086 times)
« on: March 04, 2011, 20:28:04 pm »
A tuto about preparation of imported drawings.
I do this for a French forum and I tryed to translate this in English  Roll Eyes
If someone want to correct spelling, I can send the Word file to edit ....
Edit: The last version of the pdf as been moved on reply #6
« Last Edit: March 05, 2011, 13:56:58 pm by dh42 » Logged
« Reply #1 on: March 04, 2011, 20:54:47 pm »
You have been a substantial contributor here, and I would like to contribute, as well.
I don't see many problems, but there are a few of vernacular and sentence construction, which is natural to see between languages.  Your mastery of English is exemplary.
I'm unfamiliar with how we can make contact, but chary of displaying my email address here in public.
Perhaps Andy has an "exchange" facility?
« Reply #2 on: March 04, 2011, 21:30:58 pm »
Hello LLoyd,
Thanks for your help  Wink
I attach the Word file (zip), and you can make the same after correction to reply, file is very small.
« Last Edit: March 05, 2011, 13:59:21 pm by dh42 » Logged
« Reply #3 on: March 04, 2011, 21:47:39 pm »
I shall attend to this presently.
« Reply #4 on: March 05, 2011, 01:09:31 am »
Here is a slightly fixed-up version.  I changed the vernacular a bit for native English speakers, moved one section from the end to the middle to "warn of problems before discussing solutions", and altered very little else.
My version might contain a typo or two (I hope not, but you know how reality is), but you did a marvelous job, and are to be commended.  I wish Americans spoke and wrote English as well as you.
Thanks for the chance to help.  Please ensure that none of my changes altered your meanings.  I take no offense at that.
* Prepare_drawings_Edit.zip (303.05 KB - downloaded 721 times.)
« Reply #5 on: March 05, 2011, 12:52:49 pm »
One thing in that file I definitely missed:
I would, for English, change the word "fastidious" on the last page to "tedious".  In English, it better matches what I think was Dave's intent.
« Reply #6 on: March 05, 2011, 13:58:40 pm »
Here is the corrected version of the pdf
Thanks LLoyd
* Prepare_drawings2.pdf (951.63 KB - downloaded 990 times.)
c.sitas
« Reply #7 on: March 06, 2011, 01:09:10 am »
Hey you  guys, That job is fantastic. Great work.  It's poeple like you two and a lot of the other guys on this forum that make it SECOND TO NONE. Again great Grin job. c.sitas
« Reply #8 on: March 06, 2011, 14:24:30 pm »
I can suggest one minor addition.  One can generally select almost all the lines in an imported DXF via Ctrl-A and or mouse area selection before doing the join.  Selecting a small precision for the join will then generally ensure that you get the result you want.
For drawings with many individual line segments needing to be joined, this method is much faster than individual clicks.
« Reply #9 on: March 06, 2011, 14:31:12 pm »
There is another problem about we discuss by mail with Ralf (pixelmaker)
Sometimes when spline are used and/or with certain soft, the accuracy of the drawing is too hight, and you have thousand of knot to define an arc or spline after conversion  in polylines.
That cause 3 problem.
1 the Gcode file is very long.
2 calculation time for the toolpath groves
3 my CNC can't reach the programmed feedrate and can be very slow on this hight defined polyline.(Mach3, the PC or the controller, I don't know what cause problem)
I use a method and Ralf another to solve this problem.
An important parameter is Tools/options/SplineToPolylineTolerance It control the accuracy of the resulting polyline.
look at this pictures, it's the same dxf but with 2 different values for SplineToPolylineTolerance (I use mm)
You must set the SplineToPolylineTolerance value before opening the dxf.
Ralf uses another method that allow control on each polyline, He uses the Edit/Polyline/Arc fit function.
Here is the same dxf but imported with very high accuracy.
And after usage of Arc Fit
« Reply #10 on: March 06, 2011, 15:37:28 pm »
Hello David,
thank you for starting this discussion.
I use "Arc fit" for the reduction of the nodes in Arcs. I think the difference is the SplineToPolylineTolerance affects the import of all splines, no matter if it curves or straight or angled lines. Arc fiT  has only affect only to arcs.
In addition, I can not control the outcome and the quality of the reduction of the nodes while importing and I can´t reverse the reducing process for looking of differences.
These are my thoughts, so I prefer Arc Fit.
« Reply #11 on: March 06, 2011, 20:36:22 pm »
Hello David,
Yes arc fit give more flexibility, it's a good idea  Wink
Orifice62
« Reply #12 on: March 09, 2011, 23:39:18 pm »
Thanks, dh42
We learn something new every day. Cheesy I just tried what you suggested and it worked great. I had over 2900 nodes on my project and now I'm around 250 with looks to be pretty good results.
So thanks again for the example Wink
Bret
chuckeroo
« Reply #13 on: September 28, 2016, 09:32:22 am »
I think that you just helped some one else . That would be me. Thanks.
« Reply #14 on: September 28, 2016, 21:25:14 pm »
+1  Wink
Page created in 0.168 seconds with 19 queries.
