May 24, 2018, 16:42:18 pm
Author Topic: CamBam Lathe - Short Tuto  (Read 10949 times)
« on: December 27, 2010, 23:03:32 pm »
A reminder to use lathe function.
The Lathe axis on CamBam standard view (XY plane)
And a short video attached to remember the important parameters  Wink
* Lathe_CB_EN.rar (2241.24 KB - downloaded 979 times.)
« Last Edit: December 28, 2010, 21:44:04 pm by dh42 » Logged
« Reply #1 on: December 28, 2010, 00:42:28 am »
Excellent! Thank you so much for putting that together.  It is much easier to take things in when they are presented as a video.  Smiley
The only thing I would add, is that you should also make sure ToolProfile is set to Lathe.
This is needed so the post processor can offset the toolpath by the tool radius.
Merci beaucoup David!  Grin
« Reply #2 on: December 28, 2010, 15:17:50 pm »
Hello Andy
Ok, I'll edit the video to add the setting "toolprofil"
The video is a good thing, but it makes very large files that I do not know where to host! (if I use YouTube, it's a disaster, it re-compress the video and modify the size too and result is unreadable for screenshots)
« Reply #3 on: December 28, 2010, 15:22:16 pm »
David.
I find Jing (free) to be OK for the few videos I make. Just 'shoot' and let it upload to their website.
« Reply #4 on: December 28, 2010, 15:59:11 pm »
Hello Martin
I use a similar soft to do capture (CamStudio), then I edit the avi with Ulead VideoStudio ... the problem is the size of a long tuto with big screen (0.5 to 1 GB )
I'll try Jing to see .... the major problem with CamStudio is that I can't cut the parts of film that I don't want, it's the reason why I use a video editor too ...
« Reply #5 on: December 28, 2010, 21:46:22 pm »
Video released  Wink
Totem
« Reply #6 on: December 04, 2011, 20:21:26 pm »
Hello all,
salut David ;-),
I made an other video tutorial to use CamBam with a lathe, a  bit longer as david's.
Maybe you've already seen it on a french forum.
In it, I show how I drill with a lathe, and how to do face turning (not sure it is the good expression, what I mean is machining along the X axis).
You'll find the video here: http://www.screencast.com/t/jSFex9Hn9cha
The part you see in this video is this:
It's a 4mm collet (or clamp? not sure) for my router motor.
++ Lionel
I'm french, and I'm really sorry for all my English mistakes :S
« Reply #7 on: December 04, 2011, 23:41:53 pm »
I played David's video and didn't get any sound.  Not sure if there is narration.   Huh
When I was learning CNC lathe in school we always chose Z0 at the right end of the piece with moves in -Z direction.  One reason is that we would usually take a facing cut manually with the jog pendant and then set Z0 at that tool position.
Questions:
1) Is it necessary to draw the profile in the -X half of the grid, or does it matter?
2) Is the tool diameter field used to enter the nose radius, and if so is it necessary to double the radius?
« Reply #8 on: December 05, 2011, 17:41:44 pm »
No sound on my video ; I don't speak English .. only read/write.
I tried with the profil in +X ; that don't work, toolpaths are wrong in Mach ..
Yes you must enter 2 if you want a nose radius of 1 (don't forget to use ToolProfil = Lathe)
Totem
« Reply #9 on: December 05, 2011, 17:49:10 pm »
Quote from: Kvom
If you want use a tool for turning internal diameters (outil à aléser, don't know the english name  Embarrassed ), you can't draw at the upper part off the gird (also Y+ when milling), rotate your profile of 180° around the X axis (with the "transform" dial box of course ), then generate toolpaths, and apply the same transform to the toolpaths, it will be OK.
++ Lionel
Page created in 0.297 seconds with 18 queries.
