November 21, 2019, 23:57:47 pm
Pages: 1 ... 12 13 [14]
Author Topic: Metal Nibbler Three  (Read 81775 times)
« Reply #195 on: May 02, 2019, 19:04:05 pm »
Although they're not the least-expensive, in all cases I've either been very-satisfied with the products McMaster-Carr sells, or they have graciously taken them back at no cost to me.  And that has happened only rarely in the last 20 years of dealing with them.
Yeah, but a way cover won't show its true colors for a few to several months.  Then when it has failed its really no longer returnable.
« Reply #196 on: May 02, 2019, 19:13:58 pm »
Eh... they're pretty generous about things like that.  I'm betting they'd probably guarantee it in normal service for about a year.
« Reply #197 on: May 05, 2019, 20:04:37 pm »
I hope its made of some miracle fiber.  Its a lot lighter than I expect.
I used the machine some the last few days, but using the giant vise was a bit tricky.
« Reply #198 on: May 07, 2019, 13:40:20 pm »
Old cars used to have such a hole on the front bumper. For the big starter key Smiley
« Reply #199 on: May 07, 2019, 21:41:54 pm »
I had a tractor for nearly two decades (80s and 90s) with a 'big key hole' just like that!  A 1957 Ford 8N, fully-restored, and used almost every day during the warm months (April through September).
I never once had to hand-crank it, though, and glad for it!  There were a LOT of stories circulating about men getting broken arms due to a backfire!
« Reply #200 on: May 07, 2019, 22:11:14 pm »
My dad has my grandfathers old 1950s John Deere Model M.  I used it a few times for harvesting grapes and sweet corn.  Don't recall a crank hole.  It always just started.
For the crank hole on the mill.  Obviously I need to cleanup the bur left by the hole saw, but you can't even see the hole when the doors are closed on the table top enclosure.  I think on the inside to deflect spray I'll probably mount a neoprene or buna rubber flap.  Currently I am using an air ratchet with a short extension to operate the vise, but the plan is to make a speed wheel with a slightly extended single diameter shaft so the flap doesn't hang on it when its pulled out.  I'll mill a close fit hex pocket on the end with a taper for the first 1/4 inch or so of depth.  For now the air ratchet works except that I knock the socket off every other time I use it.
« Reply #201 on: November 10, 2019, 22:04:10 pm »
As I mentioned in Chuckeroo's Y-Axis thread the Y-axis on Metal Nibbler Three has had chronic issues over the years.  I swapped out the 1:1 timing pullies to a 2:1 setup with a 14T 1" L pulley on the motor and a 28T pulley on the ball screw.  It seems to be working great.  I had to set the resolution down to 10K pulses per inch, but it works.  It actually worked at the same speed and acceleration, but I I turned it down a little anyway just for safety.
I have not run it hard yet.  By hard I mean half day long jobs cutting steel.  I have run it all day long a couple days rough cutting 18 minute jobs with a 1/2" end mill in aluminum.  In 9 hrs I probably got 7hrs of actual machining time.  I didn't constantly temperature monitor the motor, but the handful of times I ran the saddle back and reached inside the knee to feel the motor it was as no warmer than any of the other motors.
« Reply #202 on: November 10, 2019, 22:07:51 pm »
I cleaned two full 5 gallon buckets of chips (and another couple in the vacuum) after those two days.  I had to clean it out.  Coolant was starting to run out the vise handle hole in the front of the enclosure.
Page created in 0.111 seconds with 20 queries.
