Welcome, Guest. Please login or register. April 17, 2014, 13:40:13 pm
Author Topic: Coolant slinger's Tormach 1100 set-up  (Read 3643 times)
coolant slinger
« on: July 11, 2010, 20:43:43 pm »
Hey guys,
Thought I would post a pic. of my machine. It's a Tormach PCNC 1100. I have had it for about a year now and am very inpressed with it. I use Cambam for the code when needed. I also posted a project in the project section of this forum named "Pockets and Profile".
Enjoy,
Coolant Slinger
Coolant Slinger
spiked3
« Reply #1 on: July 13, 2010, 18:10:29 pm »
Nice.
I fought an X3 conversion for 2 years and finally gave up. I pretty much gave it away last week and went back to a sherline for a while.
But I have been eyeballing the tormach 770 now.  Problem is I really need a place to put it, which was part of the X3 problem, cramming too much into a small space makes it really difficult to work on.
But lesson learned - if you want to tinker with the mill do a conversion, if you want to make parts get something made for the purpose.
Problem is, assuming I build an outbuilding, for a little more I can get a full VMC on eBay.
Decisions, decisions.
lazer
« Reply #2 on: July 13, 2010, 22:17:32 pm »
Hi Mike spiked3
After days 25 of December of 2012, the life goes!
Not discouraged.  Wink
That the force be with you!
lazer = leisure -- Sorry my English
coolant slinger
« Reply #3 on: November 23, 2011, 21:47:00 pm »
Here is a pic of the machine and the full encloser I made. It keeps the coolant and chips contained.
Coolant Slinger
Coolant Slinger
Funkstar
« Reply #4 on: January 16, 2012, 18:34:25 pm »
What a nice enclosure. Thinking of doing something similar. What are the white stuff that you use for the "walls"?
P.-
coolant slinger
« Reply #5 on: January 17, 2012, 01:30:03 am »
It's corrugated plastic 4mm thick. The only bad thing is I had to buy a box of 10 sheets 48" x 48". I only needed 5 sheets. $92.50 a box. Here is the link http://corrugatedplastics.net/
It's cheaper than plexiglass.
coolant slinger
Coolant Slinger
coolant slinger
« Reply #6 on: January 12, 2014, 01:55:46 am »
Thought I would post some of the pics on how I built the table supporting my Tormach 1100. You wood workers may appreciate this.
« Last Edit: January 12, 2014, 02:03:30 am by coolant slinger » Logged
Coolant Slinger
coolant slinger
« Reply #7 on: January 12, 2014, 02:02:13 am »
The rigging and mounting of the machine. I think it weighed around 1200 pounds. It actually bent the bolt on top or the hoist (cherry picker).
« Last Edit: January 12, 2014, 16:22:39 pm by coolant slinger » Logged
Coolant Slinger
« Reply #8 on: January 12, 2014, 02:13:44 am »
Very nice.  What did you use for your waterproof coating?
http://www.YumaTackle.com
« Reply #9 on: January 12, 2014, 02:32:10 am »
Mine would be a little harder to mount like that -- 4100lb before stripping the old logic cabinets and shrouds.  It's probably still around 3700lb.
Automation Machine Design, LLC.
"Doing the impossible in pyro automation every day."
« Reply #10 on: January 12, 2014, 02:57:35 am »
_______________________________________________
+1  Cheesy Cheesy Wink
coolant slinger
« Reply #11 on: January 12, 2014, 03:33:45 am »
WestSystems 2 Part Epoxy With Silica Filler And Grey coloring. They Are Into Marine Stuff. It's Pretty Tough Stuff. Hasn.T Leaked Yet.
Coolant Slinger
« Reply #12 on: January 12, 2014, 12:16:18 pm »
Thanks for that.
coolant slinger
« Reply #13 on: January 12, 2014, 16:37:52 pm »
Pics of the epoxy I used to seal the chip tray. The shower drain, and coolant tank. The shower drain is just a standard brass one from lowes. The graymills coolant pump is plumbed with a check valve to keep the coolant from draining back and hesitating between tool changes. I also have a tee fitting on the pump that allows me to use the coolant pump to run a garden hose with hand spay noozle with a flip of a valve. This allows me to wash the inside walls of the machine using the coolant and pump. Then I coral the chips and scoop out by hand.
Coolant Slinger
coolant slinger
« Reply #14 on: January 12, 2014, 16:56:55 pm »
Pics of the door track on the encloser. Used a standard closet door track from lowes. The enclosure was made from 4mm corrugated sign material and 2" aluminum angle. I think I already stated this previously in this post sorry. The doors made from 1/4" plexiglass. And a pic of the complete workstation with the machine making parts. Holding true to Arie Kabaalstra's inspiring slogan " Why buy one, if you can build one" Thanks to everyone on this forum and CNC Zone for the inspiration. Couldn't have done it without you.
Coolant Slinger
Page created in 0.167 seconds with 18 queries.
