Support => CamBam help (General usage) => Topic started by: Nissim on May 15, 2019, 04:39:15 am
Title: Travel clearance Z height
Post by: Nissim on May 15, 2019, 04:39:15 am
Good day
I am wondering if I can set within CamBam the travel Z height above the material.
Many thanks
Nissim
Title: Re: Travel clearance Z height
Post by: dh42 on May 15, 2019, 05:56:56 am
Yes, it is the clearance plane value in each machining operation (MOP)
Post by: Nissim on May 17, 2019, 04:34:50 am
Thank you David
Your advice did the trick !!
Thank you
Post by: Bob La Londe on May 17, 2019, 16:48:44 pm
Also, if you want to default to a particular height you can set that in the styles library in the root style.  Then every operation will use that default height unless you change it or use a non-default style where its different.
Post by: Bob La Londe on May 30, 2019, 21:16:54 pm
So I do not need to increase the Z axis height in the sense that I do not need the milling bit to travel longer. I just need more clearance so I can
Could you restate the sentence in the form of a question?
Post by: dh42 on May 30, 2019, 21:54:46 pm
Don't worry BoB, it's a spam  ;)
try is IP on stop forum spam
178.62.93.49
https://www.stopforumspam.com/search
